Author Topic: Keeps hanging on Irradiencemap or render  (Read 7037 times)
NL2911
« on: May 07, 2014, 10:15:07 am »
I'm stuck with a render issue. Vray is failing to calculate the irradiance map or to render a particular part with forestpack.
I have a maxfile with a terrain and all the forest objects i use. I have an Xref loading the building.
If i render from inside the building the render is failing,  in the irradiancemap phase or in the render.
If i render exteriors, it is rendering fine...
* i have tried to render without glass
* i have tried to make new forestobjects
* Forestpack 4.2.0b / 3ds max 2014 SP5 / Vray 3.0 / using DR
Hope someone can help, with the deadline coming end of the week..
Tnx in advance!
« Last Edit: May 07, 2014, 10:17:35 am by NL2911 »
Re: Keeps hanging on Irradiencemap or render
« Reply #1 on: May 07, 2014, 10:37:42 am »
I suggest you contact directly with ChaosGroup about this issue. Similar problems with V-Ray 3 have been fixed recently, as this:
http://forums.chaosgroup.com/showthread.php?77417-Single-bucket-stuck-on-IR-map&highlight=forest
Unfortunately there is not much we can do regarding the rendering phase, since it mostly runs within the V-Ray core.
NL2911
« Reply #2 on: May 07, 2014, 10:58:59 am »
Ah tnx!
I've contacted Chaosgroup for the nightly build.
« Reply #3 on: May 07, 2014, 11:20:11 am »
Ok, anyway if i remember well those nighty changes are already included in VRay 3.00.05. If you have not this version, you would try upgrading to it.
NL2911
« Reply #4 on: May 07, 2014, 06:29:50 pm »
Still got the problem with Vray 3.00.03....
still waiting on response from the chaosteam.
« Reply #5 on: May 07, 2014, 06:53:51 pm »
Did you try with 3.00.05 ? That's the latest release.
NL2911
« Reply #6 on: May 07, 2014, 08:20:10 pm »
crap... i totally overlooked and thought the .03 was the latest.
I will install and try!
NL2911
« Reply #7 on: May 07, 2014, 11:06:52 pm »
it seems to be fixed with the latest build :)
Tnx!
