Author Topic: Need help with ForestPack max density / display etc  (Read 4791 times)
GJ4103
« on: March 24, 2020, 10:35:40 pm »
Hello
Have I scene where the forestpack not get the grass correct build. The trees and bushes works perfect but not grass. In the picture is all of the errors I get then I try other setting. Can anyone solve this for me?
Re: Need help with ForestPack max density / display etc
« Reply #1 on: March 25, 2020, 08:09:16 am »
Hi!
Thanks for contacting us. Forest Pack creates natives instances in the render engine for each scattered object. Although the process is fast and efficient, it consumes more memory if the total number of objects is excessive.
For large areas we recommend creating patches of grass rather than individual plants. The Realistic Grass tutorial will help to explain this, It's a bit old now, but the principles still apply.
If you're using our built in presets you'll see there are 2 versions for each: Detail and Field. Make sure you choose the latter if you're scattering on large areas, these use the same "patch" principle
Many Thanks,
« Reply #2 on: March 25, 2020, 09:05:20 am »
I also would suggest you take a look to this post.
It describes the technical details about this error, and how Forest distributes the items.
GJ4103
« Reply #3 on: March 25, 2020, 09:09:40 pm »
Tried it all and it is a large area grass I build used the lawn presents in FP. Tried also to high up max faces but still not work. Here is my scene and the settings. Can you see what is wrong maybe? I don't find it
« Reply #4 on: March 25, 2020, 09:35:32 pm »
GJ4103
« Reply #5 on: March 26, 2020, 05:52:52 pm »
Have collect maps, hdri with resource collector in 3ds max but the proxys don't follow with.. How can I get the proxy with the file easy? Don't realy know where the all is when I use FP libary and drag o drop the plants.
GJ4103
« Reply #6 on: March 26, 2020, 06:19:19 pm »
Send over that I have right now, so maybe you can find what is wrong. If you need more send a new messenger. Think you can use a other model in the large area and it will be the same result.. Have both tried Maxtree models and last forestpack presents lawn but same result there also
The file is 1.77 gb so that will comes in wetransfer
