Author Topic: Forest scatter other clump forest object  (Read 11018 times)
Carlos Gamundi
« on: April 08, 2025, 03:23:30 pm »
Hi. Sorry for my english.
I work in a Golf camp and i have a forest pack object create for my grass clumps. I create a new forest object for scatter in the surface by i have several problem with the slope and edge areas. I change the mode Automatic to meshes in the rendering butl no work the edge mode (create black object). The other problem with the slope is the same. I have various clumps in zone with many slope and there are floatthing and dont cut for the edge mode.
I convert all clump forest in meshes and change the clumps for the small geometry because the interception between the clumps part in plane areas and the individual meshes in slope areas dont look the same. My machine is crash with too many geometry.
Please help me, i resolve for now but the method to use forest for scatter other forest is very convienent and i like work whith them.
I have a Laptop with Intel I7 - 13620H 10 cores 16 threads
64 Gb RAM
GTX 4070 8Gb
Re: Forest scatter other clump forest object
« Reply #1 on: April 08, 2025, 03:37:46 pm »
I'm sorry to hear you're facing these troubles. Could you please specify which renderer you're using and its version? Thanks in advance.
Also, please check the Direction setting under the Surface tab (it's set to 100 by default). I recommend setting it to Surface’s Normal (0) instead. Additionally, you might try enabling/disabling the Scale to fit sloped area option. You can find more detailed information about these settings in our online reference guide.
Thanks for any further comments you can share with us. Your feedback might be valuable for us and other users who encounter similar problems.
Carlos Gamundi
« Reply #2 on: April 08, 2025, 04:28:09 pm »
Hi I am using VRay 7
All these options dont make a solution. I try all and nothing work
« Reply #3 on: April 09, 2025, 08:37:00 am »
In that case, please feel free to send us a portion of your scene where you can reproduce these troubles, and we’ll take a look at it. Thanks in advance.
