Forest Pack => Forest Pro (*) => Topic started by: Andrei on June 11, 2025, 10:08:12 am
Title: Forest Set from Layer- not updates
Post by: Andrei on June 11, 2025, 10:08:12 am
We actively use ForestSets and found a "bug." When we add an objects to a ForestSet, like we regularly do in a list, and use this ForestSet (for example, as a distribution reference), and then move those objects, Forest Pack updates in real-time. So, when I move the reference, the scattered objects in Forest Pack also move. If, in the ForestSet, I set "From Layer," then Forest Pack does not update in real-time when I move the reference object; it only updates manually when I disable and enable Forest Pack. Can this be fixed?
Title: Re: Forest Set from Layer- not updates
Post by: Michal KarmazĂ­n on June 11, 2025, 10:25:59 am
Hi Andrei,
I'm afraid that, as mentioned here (https://forum.itoosoft.com/forest-pro-(*)/moving-reference-points-in-a-forest-set/msg37733/#msg37733): "That's a limitation of the "From Layers" feature implementation - you can use the Display > Update button or directly add these reference points "directly" to the Forest Set (this way, it'll be all updated automatically)."
