Author Topic: Forest Stats  (Read 7061 times)
iCreateLtd
Forest Stats
« on: March 14, 2024, 11:25:57 am »
Hi all,
A job is taking ages to parse per frame.
I'm optimising the scene.
In FP Stats for 1 FP it says:
Build speed: 133k trees/sec
Max density: 13.3m items in area
Does that mean that there are 13.3m items on the surface, or based on the density, that's how many can fit on the surface?
Another FP says 17m items for max density.
Any clarification would be great, thanks
Re: Forest Stats
« Reply #1 on: March 14, 2024, 11:48:44 am »
Exactly, as you have pointed out, that is a value showing the approximate maximum amount of items based on the current Distribution & Areas settings (depending on the Density settings and size of the used Area(s)). I hope that helps.
