Author Topic: Include/Exclude splines as list  (Read 9023 times)
George
« on: January 25, 2011, 04:18:55 am »
Would be good to have the option to select multiple include/exclude splines, like the surface list.
yuv
  • iToo Software - CEO
    • Itoo Software
Re: Include/Exclude splines as list
« Reply #1 on: January 25, 2011, 04:24:03 pm »
Thanks for your suggestion. We will take a look to it, probably adding some additional functionality as well.
Daniel Quintero
Itoo Software
www.itoosoft.com
daniel@itoosoft.com
Krzysztof Cebula
« Reply #2 on: August 25, 2011, 06:18:10 pm »
any news about that feature? :)
« Reply #3 on: August 25, 2011, 08:40:28 pm »
We just now working at this. ;)
Although it will take some time, because we are rewriting completely the area algorithms.
Krzysztof Cebula
« Reply #4 on: August 30, 2011, 09:39:06 am »
great news :)
Krzysztof Cebula
« Reply #5 on: August 30, 2011, 05:16:57 pm »
also whhile youre at it can i request possibility to make objects in the scene working as exclusions? preferably with ciuved falloffs :) that would really be awesome. (apparently vray distance map has major performance issues when used in "inside solid" mode...)
« Reply #6 on: August 30, 2011, 07:28:39 pm »
We are working on this feature as well. As you pointed out, the challenge is how to implement it without a major performance hit, specially using complex meshes.
Krzysztof Cebula
« Reply #7 on: August 31, 2011, 12:28:22 pm »
well technically it could just find points on a surface and use it as exclude spline. as it doest have to work in 3d mode like vray distance map... just a thought :)
« Reply #8 on: August 31, 2011, 01:54:18 pm »
Yes, unfortunately there is not a simple algorithm to get the contour spline for non-convex meshes. We are evaluating several solutions for these type of objects, since we want to provide a real-time solution (if possible).
« Last Edit: August 31, 2011, 02:24:59 pm by Itoo »
Krzysztof Cebula
« Reply #9 on: August 31, 2011, 02:24:43 pm »
sounds great :)
