Author Topic: Forest with XY mode  (Read 3548 times)
Mike123
Forest with XY mode
« on: April 04, 2022, 11:56:59 am »
Just wonder why the XY mode under the surface tab can't work normally?
Pls find my attached max file.
Thx!
Re: Forest with XY mode
« Reply #1 on: April 04, 2022, 12:47:41 pm »
Hi!
Thanks for the question. The issue is that Forest Pack uses it's local X/Y plane to project scattered objects, so you need to rotate it by 90 degrees so that its Z axis is aligned with the plane. On top of that, the plane's XY axis should also be aligned to the face. I generally do this by rotating it flat to the world's XY plane, resetting the XFom and then rotating it back into its final position.
I hope that makes sense,
Mike123
« Reply #2 on: April 04, 2022, 03:49:42 pm »
I know.Thanks Paul!
