Author Topic: Pebbles in Box  (Read 4316 times)
amitgedia
Pebbles in Box
« on: May 27, 2020, 12:39:57 pm »
Hi guys,
was wondering how to make pebbles in box
tried doing it via FPP but didnt get the desired result (3dsmax 2017, Vray Next, FPP 3.6.0)
Hope somebody can help
Thanks in advance
Amit
Attaching the image to make and the max file
Re: Pebbles in Box
« Reply #1 on: May 27, 2020, 02:04:20 pm »
If such high precision is needed, then You will need some kind of physics tool to distribute, scattering is not enough.
amitgedia
Re: Pebbles in Box
« Reply #2 on: May 27, 2020, 02:47:36 pm »
Hi Rokas,
I dont require full and exact precision just want to fill the box with or scatter the box with pebbles, the box should be filled with stones thats the end goal and it should not protrude out from the sides of the box while scattering
Amit
Re: Pebbles in Box
« Reply #3 on: May 27, 2020, 02:56:15 pm »
... and it should not protrude out from the sides of the box while scattering
That is what i mean by precision, and thus requiring physics simulation.
amitgedia
Re: Pebbles in Box
« Reply #4 on: May 27, 2020, 03:34:33 pm »
Ok got it. Then i have to try physics or massfx.
there are no chances with FP or RC ?
Re: Pebbles in Box
« Reply #5 on: May 27, 2020, 03:43:38 pm »
There is a way to create the result using either FP or RC. But You would need to set up segments is "physical way" to begin with.
amitgedia
Re: Pebbles in Box
« Reply #6 on: May 27, 2020, 03:56:42 pm »
ok like stacking splines on top of each other and giving it spline thickness in FP parameters.. right ?
