Author Topic: ForestIvy Limitations? ForestIvy objects not visible after opening the file  (Read 21035 times)
3d-labor
at first: Forest Ivy is amazing! It is a big time saver. In my case I had very thin geometry. Usually for walls a lattice is used, made of thin wodden or steel bars. I noted, that this geometriy is not suitable for ForestIvy. When I used the groth setting the ivy vanished. So I used a trick. I made a big box behind the lattice and draw the ivy on that box.  That works and I got no warning of too much elements. But also after using the groth settings  the ivy vanished again. Please see my screenshots.
First is the ivy on the bars.
Second is the box behind the lattice.
Third shows that it worked, I was able to spread the ivy on all elements before it vanished
Are there limitations or what I do wrong?
Workstation: i7-3930K @ 3,92GHz 16 GB RAM, Nvidia Quadro P4000, Win7/64 Prof.
Rendernode: AMD Threadripper 2950x@ 4,10 GHz 32 GB RAM, GeForce GTX 550 Ti, Win 10 Prof.
Autodesk Building Design Suite Premium 2019, VRay Next, Cup of coffee...
RealViz
    • RealViz
Re: ForestIvy Limitations? ForestIvy objects not visible after opening the file
« Reply #1 on: September 30, 2024, 06:42:14 am »
The auxiliary surface (your big box) must be maintained. You must not delete them, just put them in e.g. a non-render/hidden layer.
3d-labor
« Reply #2 on: September 30, 2024, 07:55:29 pm »
I did so, I didn´t delete the box. Only set it to non renderable. I will now try it with smaller boxes, one per lattice.
3d-labor
After some tries now it works. I think it was a beginner error, not a software limitation.
