Forest Pack => Forest Pro (*) => Topic started by: SL7359 on August 25, 2020, 09:55:52 am
Title: ForestPack does not update immediately after editing in ForestPack.
Post by: SL7359 on August 25, 2020, 09:55:52 am
When editing on ForestPack, the data is not updated immediately, and will be updated after restarting 3dsMax.
When I open the .max data on another computer for editing, it is updated immediately. What are the possible causes?
Title: Re: ForestPack does not update immediately after editing in ForestPack.
Post by: Rokas on August 25, 2020, 10:39:29 am
It's hard to identify the issue from just the info provided. Would You attach a file and write the steps You do and what feedback You get / expect.
Post by: SL7359 on August 25, 2020, 10:57:10 am
As soon as I make an edit in the Modify panel, it should update on the view, but nothing is shown.
It doesn't happen on other computers. I would like to know the cause.
Post by: Rokas on August 25, 2020, 10:58:25 am
what edit do You make?
Post by: Rokas on August 25, 2020, 11:08:44 am
I see that manual update is turned off. It should update in real time.
Seems like it is a problem with 3ds max,- not ForestPack. Has it always been this way? What changed since it was working correctly?
(https://i.imgur.com/XW4USSu.png)
One thing i can suggest to try is to rename Your ENU folder at this location:
%localappdata%\Autodesk\3dsMax\2020 - 64bit
If that wont fix the issue, You can delete new ENU folder and rename back renamed folder to "ENU"
Let me know if that helped.
Post by: SL7359 on August 28, 2020, 04:44:13 am
I tried, but it didn't solve the problem.
