Author Topic: GAMMA 2.2 PROBLEM  (Read 3825 times)
EF1808
GAMMA 2.2 PROBLEM
« on: October 10, 2015, 07:52:19 pm »
Hello Itoo.
i have a gamma setting of 2.2. input gamma 2.2 output gamma 1.0 some of my forest objects are not looking proper in the scene. if i isolate the same object and render it then it looks proper.
if i cgange the gamma setting to use autodesk gamma lut correction then it comes properly. Please help i have project deadline.
Re: GAMMA 2.2 PROBLEM
« Reply #1 on: October 11, 2015, 08:43:24 am »
Hi, are you using 3D or 3D trees ? (i'm not sure seeing the images). What is your V-Ray version ?
For 3D trees, please try converting the trees to stand-alone objects using Forest Tools. Does the problem solve or not ?
For 2D trees you can do a similar test collapsing the Forest object to a mesh.
This test will help to identify if the problem is caused by Forest or V-Ray. Thanks.
