Forest Pack => Forest Pro (*) => Topic started by: BG4805 on August 02, 2023, 10:14:55 am
Title: ForestPro dispaears when exporting to unrealengine
Post by: BG4805 on August 02, 2023, 10:14:55 am
as i said in topic title, i don't know why but my forestPro dissapears when i export to unreal 5.2
See screenshot please.
Because it's little bit boring to reopen scene just each time for new import.
Any suggestions?
thanks.
Erick
Title: Re: ForestPro dispaears when exporting to unrealengine
Post by: Michal Karmazín on August 02, 2023, 11:47:56 am
I'm sorry to hear, you are facing trouble with it. I've done some tests with the Datasmith Exporter, but I can't reproduce any similar troubles. Are you using the File Export > Export / Export Selected or the Direct Link feature?
As you’re using the Points Cloud viewport mode please feel free to “change” the Style - Small Dot / Large Dot mode to “refresh” the viewport once the object disappears.
Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
Post by: BG4805 on August 02, 2023, 03:58:20 pm
using Files Export - Export Selected
Recorded a small vidéo if it help (just cutted the exporting time wich i around 2 mn on my old workstation)
Hope it helps
Thanks.
Erick
Post by: Michal Karmazín on August 04, 2023, 10:48:42 am
Hi Erick,
We’ve done some additional testing here, but in our scenes, we don’t face this issue. Would you mind specifying your actual software configuration (3ds Max, FP & renderer versions used)? Also, as it might be triggered to some specific setting(s), if possible, please send us (https://forum.itoosoft.com/faq/how-to-send-a-file-to-itoo-software/) your scene (ideally simplified and containing just this problematic object(s)) and we'll check it. Thanks for your speedy collaboration, your feedback is very important to us.
Post by: BG4805 on August 04, 2023, 11:08:33 am
no problem to send scene file...
Spec..3dsmax 2023/corona 10/ FP 8.2.1 /windows10
Need to move right now..but if it's ok will upload this week end.
Erick
Post by: BG4805 on August 04, 2023, 12:26:15 pm
Scene file sent via wetransfer.
Really hope it came from your side :) ...
1/to not waste ur time
2/to improve forest to unreal in, case some people have same problem
3/to not spend hours to search from my side :)
Thanks.
Erick
Post by: Michal Karmazín on August 04, 2023, 03:05:18 pm
Replied by email.
It’s fixed in version 8.2.2.
