Author Topic: Miscanthus  (Read 4828 times)
Pierre
    • Studiosezz
Miscanthus
« on: April 06, 2013, 09:41:52 pm »
I'm looking for a way to create this kind of grass. I model 5 blades and i want to scatter them in a circle. The rotation is the difficulty. How can i rotate the blade around the center of the circle and not around their own pivot ?
But Maybe it's not a good way to do. Can you help me?
Thank you ,
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: Miscanthus
« Reply #1 on: April 07, 2013, 01:17:50 pm »
Please, try the attached scene. It uses a rotation map to define the angle of each blade, so they point out to the cirle's outside
Two important tips:
1) The Forest object must have assigned a surface, to get the UVW coordinates for the rotation map.
2) Be sure to load the map with gamma 1.0, so the pixel values are interpreted correctly.
Pierre
    • Studiosezz
Re: Miscanthus
« Reply #2 on: April 07, 2013, 04:04:41 pm »
Thank you very much Carlos,
It's perfect !
Pierre
Studiosezz PARIS
www.studiosezz.com
