Author Topic: Is it possible?  (Read 3869 times)
BT4215
Is it possible?
« on: March 26, 2021, 07:02:59 pm »
Hi all,
I'm creating a modular walkway with Railclone Pro (similar to the New York High Line). I need to change the path when necessary to create different shapes.
I've created also a Forest pack Pro object for the pedestrians, they follow the same path. When I curve the walkway the people follow accordingly.
Now I need to distribute the pedestrains along this path. How can I do it? Whe I tweak the random XY positions the pedestrians don't follow the path anymore, it's like the xy transformations don't follow the vector direction. Then X transformations become Y, it depends on how the curve is oriented.
Also I have some trees following some holes in the walkway. How can I shift all the trees along the path?
Is it possible to perform this transformation?
Regards.
Re: Is it possible?
« Reply #1 on: March 29, 2021, 07:47:02 am »
Hi.
We would love to help, but it is hard to give any tips without seeing Your scene setup.
If You attached a simplified max file with Your setup so far we could examine it and give You some advises.
Please use this form to contact us if You can't attach files publicly.
Also You can use WeTransfer to link large files.
