Author Topic: Forrest trees not vertical on curved terrain  (Read 5018 times)
DU856
« on: May 03, 2014, 09:32:54 am »
Hi. Forest Pro 4.2.2 - i am not able to get vertical position of trees.
Doesn`t matter what direction i set in surface rollout the trees are not vertical...
Jozef
Re: Forrest trees not vertical on curved terrain
« Reply #1 on: May 03, 2014, 09:42:18 am »
Please, try applying a Reset XForm (Utilities panel) to the surface and collapsing it to mesh. It that doesn't help, upload a test scene so we can check it.
DU856
« Reply #2 on: May 05, 2014, 09:58:34 am »
Hi. Didn`t help. No idea how to upload the scene.
I have shared it on my Google disk:
https://drive.google.com/file/d/0B_pe7kjrpZUtelRlR01uT2lJU28/edit?usp=sharing
Jozef
« Reply #3 on: May 05, 2014, 10:35:02 am »
Hi Josef,
I can see that your Forest object is rotated. Please put the rotation to zero and refresh the Forest object (for example by hitting Update surface data icon). This will solve your issue. Please check screenshots attached.
Please note, that Forest objects are every time while rendering reconstructed based on scene position and coordinates of used splines / surfaces so it shouldn't be transformed or moved. Also we don't recommend to use any modifier over our plug-in to avoid possible issues.
Hope this helps you. Have a nice day.
Kind regards,
DU856
« Reply #4 on: May 05, 2014, 11:02:35 am »
Thanks!
