Author Topic: Spline scatter - Different spacings per spline  (Read 2660 times)
Macker
« on: February 15, 2019, 01:56:55 pm »
Hey guys,
I'm using forest pro to populate a car park and it's working perfectly, scattering cars at 2400mm intervals - however this all goes awry when it comes to disabled spaces which are all 1200mm wider than a standard space.
What would be really useful would be the ability to set different spacings for different splines.
Is this something that could be implemented?
Many thanks,
Chris
Re: Spline scatter - Different spacings per spline
« Reply #1 on: February 15, 2019, 02:03:06 pm »
You can do that with 2 ForestPack objects, or RailClone.
Macker
« Reply #2 on: February 15, 2019, 03:11:37 pm »
I'm aware I could do this with two forest pack objects, but would this not double up the amount of memory used?
« Reply #3 on: February 15, 2019, 03:57:29 pm »
No. To avoid this issue, we designed the plugin to share the geometry, between all Forest objects in the scene.
Macker
« Reply #4 on: February 15, 2019, 04:36:55 pm »
Excellent, thank you.
