Forest Pack => Forest Pro (*) => Topic started by: ZO6039 on June 30, 2025, 10:14:34 pm
I have a simple setup where ForestPack scatters spheres on terrain to simulate city lights in the distance. The spheres have VRayLightMtl materials applied to make them self-illuminated. When I render my scene locally then everything works fine, but when I try to render my scene on render farm then render crashes. By log file I assume the problem is VRayLightMtl material with Direct illumination. I made a work around by collapsing FP object to Mesh. I previously used Multiscatter plugin for such purpose and it worked fine. Could you look at this problem, please?
Thank you for reporting this. As you pointed out, when rendering via network rendering, V-Ray generates an error related to the Direct Illumination feature of the VRayLightMtl material. We'll investigate it. In the meantime, to prevent this error, please set Display > Render > Mode to Meshes.
We just contacted to Chaos about this issue: to use Direct Illumination Forest object must return a triangle mesh.
But by default, Forest generates instances of the source object and a null triangle mesh.
To fix it, just set Display->Render to Meshes, as Michal suggested.
Thank you!
