Forest Pack => Forest Pro (*) => Topic started by: oligophant on October 20, 2016, 07:21:10 pm
As the title says, why is this happening?
Latest FP, 3dmax 2014 x64, i also have latest RC, but it works fine.
Only in this scene. Should i send it to you?
Would you mind to send us (http://forum.itoosoft.com/index.php?topic=3648.0) your scene (ideally a simplified version of it) to have a look at it here? Thanks in advance.
I ran some test and intalled the latest RC and FP, and everything works as expected. But the scene is an animation, 1650 frames. I've sended to backburner to render it and on frame 560 only two nodes dont render one FP object. And gradually all the slaves dont render that particular FP object, only the pc with the floating licence render the FP.
What is happening?, and more important, How could i fix it?. This happened to me on other scenes too.
It might be a licensing issue as this kind of problems may occur with use of non-legitimate licences. Though it might be later edited with a valid license, involving the non-legitimate licence cause object damage and future troubles. Are you using any "third party" presets?
As mentioned previously, please send us (http://forum.itoosoft.com/index.php?topic=3648.0) your scene and we'll check it here.
Email with scene sended. No third party plugins, just my own library. I'll better reinstall FP vanilla style and see if that helps
