Author Topic: How do I make contoured shaped plants?  (Read 3319 times)
BK8837
« on: September 20, 2023, 07:43:20 pm »
I want to make the plants contour like plants like in the picture, but I don't want to use scale since it will make the leaves and flowers smaller. Is there a way to make this effect in Forestpack?
Re: How do I make contoured shaped plants?
« Reply #1 on: September 21, 2023, 08:55:33 am »
If you don't want to use the Transform > Scale feature for these purposes (although slight scale changes would be recoverable to introduce), you should combine several model variations. In the case of procedural models (like GrowFx), that'll be easy, but also in the case of meshes, you can, for example, prepare them by "reducing" some larger model(s) to create smaller variations.
