Author Topic: FP library meshes "Rock S3" wont network render  (Read 4837 times)
Fabrice
« on: March 31, 2021, 08:40:01 pm »
Hi all,
My Max contains several FP systems :
- most systems use instanced megascan meshes and render well
- one system uses objects from the FP "Rock S3" library. It renders well locally but renders black over the network.
Its textures are located on "C:\Users\xxxxxx\AppData\Local\Itoo Software\Forest Pack Pro\lib\3D\Stones\maps"
so I guess that's why the render node wont find it.
As they dont have the texture on their C: drive and the "external files user path" are missing on those render node Max instance.
Is it a rendernode install issue?
How can I fix it please?
Fabrice
Max 2017 + FP 6.2.2 + Redshift 2.6.54
Fabrice
Max 2017 + FP pro 7.4.3
Re: FP library meshes "Rock S3" wont network render
« Reply #1 on: April 01, 2021, 07:52:40 am »
Hi. Seems like libraries are not yet installed on Your render node.
You need to install them on it. Hopefully this documentation page will help.
Fabrice
« Reply #2 on: April 01, 2021, 11:18:18 am »
Thanks Rokas,
I copied the folders on the "C:\Users\xxxxxx\AppData\Local\Itoo Software\Forest Pack Pro\lib\3D\Stones\maps" rendernode's folder,
the textures are present but it still renders black and diplays an error message.
Fabrice
« Reply #3 on: April 01, 2021, 12:05:36 pm »
can You check if render node "3dsMax.ini" file has the directory with where the maps are located.
Fabrice
« Reply #4 on: April 01, 2021, 03:03:37 pm »
Yes that's exactly what I did in the meantime, and now it works!
Thanks Rokas.
But it's really tedious, why cant FP do all those things for me?
I guess everybody is network rendering...
Fabrice
« Reply #5 on: April 01, 2021, 03:21:20 pm »
It does this most of the times automatically. I am not sure why it did not do it this time.
