Author Topic: FP Quad Menu Missing  (Read 5738 times)
iCreateLtd
« on: June 11, 2022, 06:20:08 pm »
Select all forest dependencies is missing from my quad menu.
I've just installed Max 2022 and have an up to date FP/RC and have looked in the quad menu options but can't find how to add the options.
I've downloaded the FP Toolbox (v1.8) and that's working but would prefer the quad menu
Any ideas?
Re: FP Quad Menu Missing
« Reply #1 on: June 11, 2022, 07:58:01 pm »
Try manually execute forestpack.ms located under C:\ProgramData\Autodesk\ApplicationPlugins\ForestPackPro2023\Contents\scripts\startup.
iCreateLtd
« Reply #2 on: June 11, 2022, 08:46:06 pm »
Ha
That worked.  Will that now be in max whenever I load it?
I am noticing that some of my settings aren't being saved.  For example, some toolbars are loading with Max even though I removed them and saved the scene/UI.
Also a Corona setting that I changed keeps changing back when loading Max.  It's as if Windows isn't writing to file properly.
Thanks!
