Author Topic: limit to visibility checking by bounding box  (Read 3322 times)
frodo
« on: May 06, 2021, 08:39:54 am »
this is just idea for improvement. Its a long time FP problem, when you use Limit to camera visibility. Its a bit useless when camera moving verticaly becase checking of visibility is done from pivot and not from bounding box. Imagine you have tall trees, so the height exceeds default 15% extend and the trees starting to popup or disappear. Increasing extend is not a solution because then is unnecessarily big and its no point to use it anymore. So the solution is checking the visibility by bounding box.
Re: limit to visibility checking by bounding box
« Reply #1 on: May 06, 2021, 08:55:19 am »
Would You please a create simple max scene to illustrate the problem ?
frodo
« Reply #2 on: May 06, 2021, 09:04:39 am »
Here it is. As you can see camera is moving up and the boxes should be visible all the time.But because the checking is done on pivot level they disappearing.
« Reply #3 on: May 06, 2021, 09:16:12 am »
There is a back Offset parameter to bring them back.
Maybe in some distant future version this can get some attention, if gets requested more.
frodo
« Reply #4 on: May 06, 2021, 09:24:12 am »
Aaaah, never touch this one. But anyway this could be problem with long lenses, so checking by bounding box will be always better.
Thanks.
