Forest Pack => Forest Pro (*) => Topic started by: g_lab on June 15, 2018, 06:31:33 pm
Is silent installation of forest pack 6 on rendernodes the same as in previous versions?
When installing FP on my workstation I defined a network path for the libraries and assets.
Shouldn't there be a parameter to tell the rendernodes where to look for the assets on the network?
Fo the last silent install I used this line which worked fine:
ForestPackPro541.exe /S /MAXVER=max2016-64 /MAXDIR=C:\Program Files\Autodesk\3ds Max 2016 /LICMODE=rendernode
Can I reuse it after updating the file name?
Yes silent install should be modified if You want to speedup and save bandwidth with parameter :
/SHAREDFOLDER=<network path for shared files>
You will also need to separately run update manager to install those updates.
We are preparing a guide for silent/offline/customPath render node install.
Stay tuned.
