Author Topic: FP7.0.9 performance issues  (Read 8318 times)
FStorm
« on: April 03, 2021, 12:39:46 pm »
FP7.0.9 performance issues on 3dsmax2022
Re: FP7.0.9 performance issues
« Reply #1 on: April 03, 2021, 01:43:25 pm »
Can confirm. Thank you.
suppenhuhn
« Reply #2 on: April 06, 2021, 01:46:18 pm »
3ds Max 2019 as well...MASSIVE performance issue. Makes it almost unusable - i.e. Click on Forest Toolbar to add a ForestObject -> Max freeze, selecting existing ForestObjects lasts nearly forever :(
« Last Edit: April 06, 2021, 01:50:54 pm by suppenhuhn »
« Reply #3 on: April 06, 2021, 01:51:15 pm »
3ds Max 2019 as well...MASSIVE performance issue. Makes it almost unusable - i.e. Selecting ForestObjects lasts nearly forever :(
To narrow the issue, would You please confirm that this is in Point-Cloud mode only, right ? At least that is happening with 2022 that we can confirm. We have not seen this in 2019 yet.
« Last Edit: April 06, 2021, 01:57:09 pm by Rokas »
suppenhuhn
« Reply #4 on: April 06, 2021, 01:59:05 pm »
Can't confirm if it's in Point-Cloud only but i was using this mode - to find out if it's a specific FO all existing ForestObjects ( 3 ) were deleted one by one ( took almost 15 minutes! ), placing a new one was impossible: clicking on the Toolbar to place a new FO -> max freezes. Using Max 2019 & latest VRAY 5
Have to uninstall it - we've got to finish a project ASAP
« Last Edit: April 06, 2021, 02:03:24 pm by suppenhuhn »
« Reply #5 on: April 06, 2021, 02:04:48 pm »
Which exact FP version were You using ?
suppenhuhn
« Reply #6 on: April 06, 2021, 02:13:38 pm »
Sorry didn't see it's a 7.0.9 post - we're using was 7.0.7
I've tried it with 7.0.9. -> same issue
« Last Edit: April 06, 2021, 02:22:36 pm by suppenhuhn »
« Reply #7 on: April 06, 2021, 02:28:12 pm »
We have fixed collisions bug, which could have caused massive slowdowns. Please try it now.
Regarding Max 2022 we found that disabling "Improve Quality Progressively" solves menu slowdown, as reported by FStorm.
Hope this helps.
« Last Edit: April 06, 2021, 02:30:24 pm by Rokas »
« Reply #8 on: April 06, 2021, 02:29:59 pm »
Would You please send us Your scene. We would like to troubleshoot it here.
suppenhuhn
« Reply #9 on: April 06, 2021, 02:49:44 pm »
thank you!
i've sent it via wetransfer to helpdesk@itoosoft.com - as mentioned the forestobject's used in that scene have been deleted - but the issue placing new forest pro objects still occures. After clicking FP - Icon on the Toolbar - Max freezes
« Last Edit: April 06, 2021, 02:56:32 pm by suppenhuhn »
« Reply #10 on: April 07, 2021, 07:37:03 am »
Thank You for the file, suppenhuhn. In our tests it seems like scene is slow, ForestPack has nothing to do with it.
Opening this scene (not very large) takes more than 5 minutes. Even longer time is needed to open Material Editor.
Easy fix for this scene- merge all it's contents to new, empty, 3ds max scene. After doing that there is no problem creating FP items.
Hope this helps.
P.S.
Please create separate forum threads. As most of the times issues reported by different users are not related. It's easier for us to track the issues, and provide personalized help.
Also, users subscribed to their threads won't get false notifications.
FStorm
« Reply #11 on: April 07, 2021, 08:36:27 am »
Does this mean 3dsmax2022 is a problem? or is it just a temporary solution?
« Last Edit: April 07, 2021, 08:40:38 am by FStorm »
« Reply #12 on: April 07, 2021, 08:39:18 am »
We still don't know. We are investigating the options.
Does that help for You?
FStorm
« Reply #13 on: April 07, 2021, 08:41:28 am »
yes
suppenhuhn
« Reply #14 on: April 07, 2021, 10:15:28 am »
Hope this helps.
Hi, thanks for your quick response! This is already a merged scene  ;D so i don't know what could cause this issue. As you said this isn't a complex scene at all nor it's large ( was it 50mb ? ) . We're continue working on that project today afternoon with FP 6 and i'll give you a short Feedback if you will.
« Last Edit: April 07, 2021, 12:28:34 pm by suppenhuhn »
