Author Topic: Spline path distribution crashes max (scene attached)  (Read 2747 times)
Arqrenderz
« on: April 01, 2021, 06:39:13 am »
Hi, im having some bad crashes here just trying to use a spline as a path, its not with all the splines but with a lot of them.
Managed to get a reproducible file.
The moment i select the path with Spacing option enabled max crashes, if i have vertex position enabled it works.
« Last Edit: April 01, 2021, 06:43:04 am by Arqrenderz »
Re: Spline path distribution crashes max (scene attached)
« Reply #1 on: April 01, 2021, 08:33:44 am »
Hello. I can reproduce it here.
Thank You for the report and attached scene file.
« Reply #2 on: April 01, 2021, 10:15:44 am »
Some of these splines are malformed because include empty sub-splines (without any vertex).
That was causing the crash in Forest. We added a check for this case, which be included in the next update.
Arqrenderz
« Reply #3 on: April 02, 2021, 06:50:54 pm »
Hi thx for the quick response! is there a way to delete those ghost splines??
I tried  a bunch of things but none worked...
« Reply #4 on: April 03, 2021, 09:27:20 am »
Please, try running the attached maxscript with the spline selected. That will remove the orphan lines.
