Forest Pack => Forest Pro (*) => Topic started by: KO3272 on January 18, 2019, 01:25:39 am
We have just updated to Max 2018 and I have noticed something odd that seems specific to FPP.
We have some copy and past scripts where you can select a single, or multiple FPP objects and copy and paste to another file. This used to work great as it automatically took all the dependencies.
Now in 2018 this doesn't work - it copies the FPP but nothing else.
I then tried to do it manually in the max layer dialogue - if you select the surface object it selects the dependencies including the FPP object. If you select the FPP object however it doesn't select any dependents.
I realise that there is the right-click menu to select dependencies but this is not as good as it doesn't work when multiple FPP objects are selected.
This problem does not occur in max 2016.
I have modified one of the scripts to work with ForestPack Pro / RailClone Pro in 2018+ versions.
Check it here (https://forum.itoosoft.com/forest-pro-(*)/bug-report-3ds-max-2019-save-selected-forest-pack-railclone-bug/msg22613/#msg22613).
Thanks very much - I will check it out.
