Author Topic: Particle flow mode issue  (Read 3841 times)
Pixelpark
    • Pixelpark
« on: April 18, 2023, 09:54:56 am »
Hi there.
I'm just trying to use the Pflow mode with a forest object, but I have this issue: I want to use as geometry a cylinder and a cone, but it comes out that some particles show only the cylinder, while others show the cylinder and a cone overlapped (see enclosed picture).
Why this behavior? I would be able to have randomly distributed cones and cylinder, but just one object for each particles (as it is when I use standard distribution method like image or path).
Can some one help me?
Thanks, cheers
Re: Particle flow mode issue
« Reply #1 on: April 18, 2023, 11:23:37 am »
Hi, thanks for the question. It could be that you have particles on top of one another. If you can upload the sample file I'll be happy to take a closer look.
Pixelpark
    • Pixelpark
« Reply #2 on: April 18, 2023, 11:42:33 am »
Hi Paul, you'll find here enclosed the max file with the whole setup.
I'm not so expert in Pflow, probably there is something wrong in my setup...
Let me know!
Cheers
« Reply #3 on: April 18, 2023, 12:20:11 pm »
Thanks for reporting this and the file. I've checked it out and your setup is correct, it appears there may be a bug in Forest Pack that I could reproduce with PFlow and TyFlow. We're looking into it.
Much appreciated,
Pixelpark
    • Pixelpark
« Reply #4 on: April 18, 2023, 12:49:28 pm »
Ok, thanks and I'm waiting for a fix!
Regards
