Forest Pack => Forest Pro (*) => Topic started by: Tomas on June 13, 2018, 01:37:24 am
Hallo,
I have a litle problem with freezing forestpack dialog when I click to FP object. It actually freezes 3ds max for 15 seconds. I have two computers and two licences. One machine works great, when I click to FP object, the dialog appear quickly, but on second computer, I have to wait for 15 seconds to open the dialog. Both machines run win7, 3ds max 2017 and DP 5.2.0. The problematic computer has standalone licence. The second computer has network floating licence.
Any suggestion? I tried to disable firewall, antivirus etc, but still the same.
Thank you.
It's a strange issue, because Stand-alone license should load faster than Network. Standalone is loaded locally from disk, while Network must initiate a connection with the server.
Please, would you change temporary the problematic computer to use the Network license, and check if there is any difference ? It can be done with the "Change License Mode" tool.
