Forest Pack => Forest Pro (*) => Topic started by: EF1808 on October 10, 2015, 07:52:19 pm
Title: GAMMA 2.2 PROBLEM
Post by: EF1808 on October 10, 2015, 07:52:19 pm
Hello Itoo.
i have a gamma setting of 2.2. input gamma 2.2 output gamma 1.0 some of my forest objects are not looking proper in the scene. if i isolate the same object and render it then it looks proper.
if i cgange the gamma setting to use autodesk gamma lut correction then it comes properly. Please help i have project deadline.
Title: Re: GAMMA 2.2 PROBLEM
Post by: iToo on October 11, 2015, 08:43:24 am
Hi, are you using 3D or 3D trees ? (i'm not sure seeing the images). What is your V-Ray version ?
For 3D trees, please try converting the trees to stand-alone objects using Forest Tools (http://docs.itoosoft.com/display/FORESTPACK/Forest+Tools). Does the problem solve or not ?
For 2D trees you can do a similar test collapsing the Forest object to a mesh.
This test will help to identify if the problem is caused by Forest or V-Ray. Thanks.
