Author Topic: Resizing brush  (Read 2881 times)
MH4288
Resizing brush
« on: November 27, 2023, 10:15:17 pm »
I would love to see this feature. Just regular brush but insted of placing instances it would resizing down or up as you draw in viewport. Is this possible please?
Re: Resizing brush
« Reply #1 on: November 28, 2023, 09:33:28 am »
Thank you very much for your suggestion. We evaluate its implementation in future releases. Let me mention, that you can already paint interactively using the Vertex Color map driving Forest's Transform values, having the Auto check-box under the Surface roll-out marked. The Vertex Paint modifier should be set to Channel - Map Channel mode and this needs to correspond to the channel chosen under the Transform - Scale - Map channel value in the Forest object.
