Author Topic: Paint stroke below polygons  (Read 2931 times)
JS4753
« on: July 05, 2016, 04:55:53 pm »
I've got a question: When painting a forest it sometimes happens that the paint strokes are placed below or above the polygons I am painting on. The forest objects themselves are in the right place. It's surely pretty simple but I can't figure it out  :P I already tried with reset xform but that didn't help. Pivot point is also in the correct position.
I attached a picture where on the right side the strokes are correctly placed on top of the polygon and on the left side they are placed below the poygon I am painting on  ::)
Thx & greetings
Re: Paint stroke below polygons
« Reply #1 on: July 06, 2016, 10:53:07 am »
Did you perform any change(s) on such surface / its topology after the Forest object creation (the Paint Area isn't linked to the surface)?
I would suggest you to try rebuilding the Forest object by pressing the Update surfaces data button or marking the Auto check-box (to Update surface data automatically - this may add a performance hit for complex surfaces). Is there any difference?
JS4753
« Reply #2 on: July 06, 2016, 11:06:46 am »
Thx for your answer,
no I didn't perform any changes to the surface after the forest creation. Auto update check box for surfaces is checked, doesn't make a difference  :-\
It is possible to work like that although it makes it a bit more difficult to paint because I can't see where I am painting  ;) But I am trying to figure out the reason for the strange behaviour as it doesn't make any sense to me. I assume it is somehow linked to the surfaces geometry. I also chencked the poly's normals, they are all correct...
« Reply #3 on: July 06, 2016, 11:24:47 am »
As you've pointed out, that might be something specific for your surface topology as we can't reproduce similar troubles. Please feel free to send us your scene and we'll check it here.
