Author Topic: toggling Scene states and Geometry Layers turns off Forest Pack visibility  (Read 3283 times)
Coastalvis
I have noticed that if you change scene states or switch a layer off/on Forest pack objects will automatically hide themselves which is making rendering automation impossible. I may be missing something here but I have tried fixing the problem in several ways but the behavior seems to continue.
Can You be more specific about the issue?
Surely if You hide layer which contains ForestPack object- ForestPack object will be hidden.
Coastalvis
Hi yes I will try to put a broken down example together for you today. The issue seems to arise when you are using Scene states to hide/unhide different layers in your scene. The forest pack objects seem to act randomly when you have this setup. Where even turning layers on and off will hide the forest pack object even though its not on that layer. Sounds confusing when I write it and will try break it down into repeatable steps.
