Author Topic: Vray Render Parameters Camera Override  (Read 2612 times)
Jim Kessler
« on: September 15, 2016, 09:27:40 pm »
In producing stereoscopic 360 panoramas we have noticed an issue when Forests are set to limit visibility with or without Camera Auto-assign on. FP does not pickup the override from the camera section of the render panel. Is this something that could be added to FP? Thanks.
Re: Vray Render Parameters Camera Override
« Reply #1 on: September 16, 2016, 01:47:09 pm »
When using the Limit to visibility feature, the camera's field of view is taken from the assigned Camera object and renderer's proper Camera settings are ignored (as for most of these special Camera Types doesn't bring any advantages).
Please double check, the Camera is set to None (if not, please hit the Clear button) and the Auto assign to active view check-box isn't marked.
If the issue persist, would you mind to provide us more details regarding your issue (a screen-shot / affected scene would be ideal)? Thanks in advance.
