Author Topic: Grouped proxies in reference mode crash Vray 7 GPU  (Read 45631 times)
ritoo
« on: December 24, 2024, 05:32:40 pm »
If a group containing vray proxies* serves as geo for a forest in reference mode - it'd crash Vray 7 GPU 100%.
*- a group of regular meshes instead of proxies renders fine. Vray CPU renders grouped proxies just fine.
Please fix it!
P.S. grouped proxies in the regular image mode do work (though in one case of (progressive rendering)  I had some wild PC freezing, the mouse barely moved). Vray 6 GPU doesn't have this issue.
« Last Edit: December 24, 2024, 06:01:28 pm by ritoo »
Re: Grouped proxies in reference mode crash Vray 7 GPU
« Reply #1 on: December 26, 2024, 09:36:14 am »
I cannot reproduce this issue. I used a group of teapot proxies distributed by reference mode, FP 9.1.6, Max 2025, V-Ray 7 Hotfix 1.
Please, send us a simplificated scene and we'll test it here.
ritoo
« Reply #2 on: December 26, 2024, 01:08:10 pm »
Thanks for reply, I sent. Is it OK on your end? I used Max 2023, don't think it matters.
« Last Edit: December 26, 2024, 01:12:12 pm by ritoo »
« Reply #3 on: December 26, 2024, 01:34:16 pm »
With your scene i can reproduce the problem here.
According to the debugger, crash happens in one of the V-Ray modules. I just reported it to Chaos.
ritoo
« Reply #4 on: December 26, 2024, 01:46:12 pm »
nice, thank you
ritoo
« Reply #5 on: January 11, 2025, 10:03:14 am »
In attached picture (group-v7) you can see yet another problem with groups in vray7. The group members (meshes this time, no proxies) are rendered in wrong (random) order. instead of pyramid+torus+teapot combo I get 3 teapots (and it changes randomly in the next render). Vray 6 doesn't have this problem.
Is it also Vrays 7  inner problem?
Please sort it out ASAP 'cause groups as geo is essential thing for us
P.S. Less important: With any vray version, when forest is displayed in proxy mode, all group members are being placed in one point, which is wrong (see group22.png).  The cloud mode shows it right way though.
« Last Edit: January 11, 2025, 10:19:47 am by ritoo »
« Reply #6 on: January 13, 2025, 08:45:22 am »
Probably it's the same problem.
Chaos confirmed us the crashing issue is a bug introduced in V-Ray 7 GPU. They will release a fix asap.
I will check the viewport bug, which has not relation with the other issues.
ritoo
« Reply #7 on: January 15, 2025, 10:01:23 am »
Firstly, no more crashes with the latest vray build. Grouped proxies in reference mode are rendered right as well. Many thanks!
However, grouped geometry in image distribution mode is rendered wrong way - only one group member (instead of whole group) is rendered, or (if group members are proxies) vray substitutes all group members with one.
In reference mode vray also substitutes all group members with one group member (see the picture above)
« Last Edit: January 15, 2025, 10:04:54 am by ritoo »
« Reply #8 on: January 15, 2025, 11:42:24 am »
I can confirm this problem happens also with the latest nightly build, although the crashing bug is fixed.
I just reported it to the Chaos team.
ritoo
« Reply #9 on: February 05, 2025, 01:14:46 pm »
Hello, today I tried the most recent build of FP+Vray 7 and it  appears the "groups as geo" support is broken:
1.Group as Geo+VrayCPU+FP in image mode       = only one group member is scattered.
2.Group as Geo+VrayGPU+FP in reference mode  = one group member substitutes all other group members (see attached pic)
3.Group as Geo+VrayCPU+FP in reference mode  = OK
Since you got ins in Chaos, could you please help to resolve (preferably preferably for a long period :) the issue?
P.S. Chaos Scatter renders groups correctly
« Last Edit: February 05, 2025, 02:21:24 pm by ritoo »
« Reply #10 on: February 06, 2025, 09:23:15 am »
Hello, Chaos just included the GPU fix in the latest nigthly compilation (build 32953). Please download and test it.
Regarding problem 1, i cannot reproduce it. Group works fine in CPU mode.
I used the attached test scene (just switch from GPU to CPU mode). Please, can you compare it with your scene ?
ritoo
« Reply #11 on: February 06, 2025, 11:39:40 am »
I sent an example to Helpdesk, is it reproducible in it?
« Reply #12 on: February 06, 2025, 11:54:06 am »
In this case, items in the group are not visible because are colliding between them, and Collision checking is enabled.
Please try to separate items in the group, or adjust collisions settings.
ritoo
« Reply #13 on: February 06, 2025, 12:00:19 pm »
Oh! you nailed it :) Thank you so much
But is there a way to tell collisions to treat the group as one entity? If there isn't one, could it be implemented?
ritoo
« Reply #14 on: February 06, 2025, 12:11:15 pm »
I took a look, it works this way in Chaos Scatter. Frankly, its rather logical..
