Author Topic: help!!! forest with in a forest  (Read 7388 times)
mikegentile
« on: August 08, 2014, 12:13:42 am »
hi
 i'm using a forest object with in a forest object
The nested forest object the forest color material it isn't randomizing
in the image
the box and the teapot and the tourus are the orginals
the  next to over are the nested forest objects and the color is randomized nicely
the objects in the back aren't
is there a way to do this?
Re: help!!! forest with in a forest
« Reply #1 on: August 08, 2014, 08:51:50 am »
It can be done using Map/Tint by Element. In your scene, the "house" material uses it, but "tree" material is on Item mode.
If you want to randomize complete items, but not elements parts, then it's not possible because internally nested objects are handled as a collapsed mesh. There is not reference to the original items.
Alternatively you would use groups instead nested. In this case, each object is scattered individually, but keeping the group disposition. To do it, just create a group and assign it to Forest selecting by name (picking doesn't work for groups).
mikegentile
« Reply #2 on: August 08, 2014, 03:52:16 pm »
thanks....i'll group them.
-mG
mikegentile
« Reply #3 on: August 08, 2014, 05:22:03 pm »
 quick question
i like the group method, but what do i do if i have all the houses placed already?  Since I cant choose it by name?????
mikegentile
« Reply #4 on: August 08, 2014, 10:59:51 pm »
i have hundreds of single houses placed and i need to repace them with groups....any suggestions?
mikegentile
« Reply #5 on: August 08, 2014, 11:15:52 pm »
my forest in a forest doesn't work with vray proxies....the nested forest renders the vrmesh funny.
« Reply #6 on: August 09, 2014, 10:44:47 am »
No, proxies cannot be used with nested Forest objects. This configuration is not supported.
« Reply #7 on: August 09, 2014, 10:48:50 am »
Why not replace the source in the Geometry rollout ? Just assign the group as Custom Object, instead the nested. Forest should keep the existing distribution.
mikegentile
« Reply #8 on: August 11, 2014, 07:16:42 pm »
Hi Carlos
thanks for all of you help btw.
i try picking the group and it doesn't update :(
however i start with the group it works as you state.
ps i'm on 4.1.6
mikegentile
« Reply #9 on: August 11, 2014, 07:18:52 pm »
it keeps the distribution, but not the updated group ( with the trees)
mikegentile
« Reply #10 on: August 11, 2014, 07:28:35 pm »
here is the file and you can see the geometry is pointing to the group but it's not updating.
« Reply #11 on: August 11, 2014, 07:57:38 pm »
Yes, i was now trying it. The procedure works for Generate mode, but not for Custom Edit. Unfortunately i don't see a way to do it easily.
Did you try the other solution ? (using Tint by Element)
