Forest Pack => Forest Pro (*) => Topic started by: sreyes on February 22, 2022, 10:08:06 pm
Title: Help, Layered lawn not rendering
Post by: sreyes on February 22, 2022, 10:08:06 pm
My layered lawn is not rendering. Shows in viewport but nothing when I render. See attached photo. I have also attached my scene. Trees come in fine, grass is no bueno.
SCENE: https://semkeforensic.sharefile.com/d-s8187b503a89a4150b467da09f6263ded
Any help will be nice. Thanks,
Using latest Arnold Build and Forest Pack 7.3.1, max 2022
Title: Re: Help, Layered lawn not rendering
Post by: sreyes on February 23, 2022, 03:04:32 pm
Still cant figure it out. If someone can help steer me in the right direction that would be great. Thanks,
Post by: Paul Roberts on February 23, 2022, 05:29:28 pm
It would appear as though you are scattering a large number of items and hitting one on our density limits
(https://i.imgur.com/AaX8Gck.png)
You can set the various limits in the display rollout to zero to remove these restrictions, but it would also appear that you are using a "detail" preset to cover a large area. We'd recommend using a "large" preset which scatters larger patches and is better suited to large areas such as these.
I hope that helps,
Post by: RBlock on February 23, 2023, 03:59:41 pm
I also have the problem - but I used the large preset. The rendering just refuse to get going. When you delete the large lawn, it renders again. I have just updated this morning to the latest revision and did not have a problem before
Post by: Paul Roberts on February 24, 2023, 10:43:03 am
Did you download 8.0.9 which was released during yesterday. We identified an issue with 8.0.8 that may have affected some users and released a quick patch. If the problem persists with 8.0.9 please let me know.
