Author Topic: Scatters too uniform almost on a grid  (Read 3257 times)
DP1633
« on: February 23, 2023, 10:56:08 am »
Always had this issue but never really tried to solve it before.  Whenever I do a scatter, say of leaves on a road and I need quite a few leaves the scatter is too uniform within the distribution.  If I select patches 1 as the distribution image then I can see the leaves are varied around the edges but in the middle they are grid-like, I would expect some to be much closer and overlap.  Any ideas, I've attached an image below to hopefully explain in visual terms better.
ST3200
Re: Scatters too uniform almost on a grid
« Reply #1 on: February 23, 2023, 02:43:32 pm »
Have you tried to use Transform > Translation > x and y values ?
DP1633
« Reply #2 on: February 23, 2023, 09:12:51 pm »
I tried that but afraid not.  It's strange because if I create a forest pack preset with leaves it displays how I would expect it to look with the leaves in the square at the top (see attached) yet if I create a new forest pack and add my own leaves then I get the grid.  I've gone through the settings and I can't see any difference.
« Reply #3 on: February 24, 2023, 10:40:05 am »
You might find this excerpt from yesterday's live stream helpful - it mentions break up grid like distributions
https://www.youtube.com/live/AHUzBqnf9ho?feature=share&t=4698
Cheers!
