Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
How can I collect the indexes of the trees in selection via maxscript ?
« previous
next »
Print
Pages: [
1
Author
Topic: How can I collect the indexes of the trees in selection via maxscript ? (Read 4280 times)
cc8boy
Sr. Member
I'll do my best.Welcome to www.c7design.cn .
on:
May 03, 2017, 09:26:43 am »
Hello everyone,
I tried input ”showinterfaces $” in MAXscript listener and I got these below.
Interface: trees
Properties:
Methods:
<void>create <point3>p <float>width <float>height <integer>geomid
<void>delete <integer>n
<void>edit <integer>n <float>width <float>height <integer>geomid <integer>seed
<integer>count()
<void>move <integer>n <point3>p
<void>setPosition <integer>n <point3>p
<void>setRotation <integer>n <point3>angle
<void>setWidth <integer>n <float>width
<void>setHeight <integer>n <float>height
<void>setSize <integer>n <point3>size
<void>setGeomID <integer>n <integer>geomid
<void>setSeed <integer>n <integer>seed
<point3>getPosition <integer>n
<float>getWidth <integer>n
<float>getHeight <integer>n
<point3>getSize <integer>n
<point3>getRotation <integer>n
<integer>getGeomID <integer>n
<integer>getSeed <integer>n
<matrix3 by value>getFullTransform <integer>n
<void>update()
<void>update_ui()
<boolean>getRenderID <INTPTR>shadeContext_ptr <&integer>itemID <&integer>elemID
itemID is In and Out parameter
elemID is In and Out parameter
<INTPTR>getRenderNode <integer>n
<INTPTR>getRenderNodes <&integer>numnodes
numnodes is In and Out parameter
<void>clearRenderNodes()
<boolean>getRenderData <INTPTR>data <integer>itemIndex <integer>faceNumber
Actions:
Interface: ForestPack
Properties:
Methods:
<void>registerEngine()
<integer>exportData <TSTR>filename <TSTR>fieldlist
<void>setEngineFeatures <INTPTR>features
Actions:
Interface: scatalog
Properties:
Methods:
<boolean>openBrowser()
<boolean>closeBrowser()
<void>refresh()
<integer>getMacroCount()
<TSTR by value>evalMacro <&TSTR>name
name is In and Out parameter
<TSTR by value>getMacro <&TSTR>name
<boolean>setMacro <&TSTR>name <&TSTR>value
value is In and Out parameter
<boolean>setOverlay <&TSTR>bitmap <integer>alpha
bitmap is In and Out parameter
<TSTR by value>getSelItemName()
<TSTR by value>getSelItemProp <&TSTR>prop
prop is In and Out parameter
<TSTR by value>getSelItemCustomProp <&TSTR>prop
<integer>getItemCount()
<integer>getSelItem()
<boolean>setSelItem <integer>index
Actions:
Interface: catalog
Properties:
Methods:
<void>refresh()
Actions:
My question is how can I collect the indexes of the trees in selection when the Forest is in “subobjectLevel = 1” ?
It seems there are no command about the indexes of selection. Can you show me some sample commands in MAXscript ?
(MAX2014 64bit Vray 3.3 Forest pro pack 4.4.1)
I am looking forward to your answer.
Logged
ITOOSOFT
Hero Member
Re: How can I collect the indexes of the trees in selection via maxscript ?
Reply #1 on:
May 03, 2017, 12:28:23 pm »
I'm afraid, it's not currently possible to access by maxscript values of the sub-object level selection.
Logged
cc8boy
Sr. Member
Reply #2 on:
May 07, 2017, 04:31:32 am »
Oh my god. This is very very important step in my new Maxscript tool. If it is not possible to access by maxscript. My maxscript will be failed.
Can you show me any workarounds ?
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
