Author Topic: Problem with exporting Scale coordinates with Forest Exporter  (Read 7081 times)
Olstatt
Hey team,
I found an issue with exporting the correct scale coordinates with the Forest Exporter into an XML file.
It seems that it exports correctly when I have the Random scale enabled under the Transform tab. But if I'm using just the Falloff Scale functions (under the areas tab) then these are not registered in the XML file.
Is it possible to fix this?
Thank you.
Re: Problem with exporting Scale coordinates with Forest Exporter
« Reply #1 on: April 19, 2024, 08:38:40 am »
Thank you for reporting this issue. With your help, I've been able to reproduce this behavior as well. As you have pointed out, scale values are not influenced by the Scale Falloff feature, although the localTM and finalTM values are correct. This will need to be investigated in more depth by our main developers, and hopefully, it will be something that can be fixed soon.
Olstatt
« Reply #2 on: April 23, 2024, 12:21:25 am »
Thanks for looking into it. It would be great to have a fix at some point, especially since this can be a useful feature for data transferred into another software (in this case for Unreal).
