Author Topic: Material Problem  (Read 3036 times)
lingrenddd
Material Problem
« on: October 17, 2020, 08:04:17 pm »
I used the default grass library of the forest package, but after I modified the color of the grass geometry, the scattered grass did not change. Later, after I picked up the grass geometry again in Geometry, the scattered forest changed its color. Why is this?
Material problem
Re: Material Problem
« Reply #1 on: October 19, 2020, 08:03:09 am »
Hi.
General note: do not pick material from ForestPack object itself (If You see *automat* in material name You picked wrong ForestObjects Dynamic material, do not modify/use that material ).
Pick materials from withing ForestPack Rollout, "Material" Button:
lingrenddd
« Reply #2 on: October 19, 2020, 09:17:22 am »
OK! Thank you very much! :)
