Forest Pack => Forest Pro (*) => Topic started by: CQ1841 on December 15, 2010, 02:36:20 am
Hopefully you can see what's going on here. It's a test scene, but the real application is on a multi-storey building with gardens on balconies. This current limitation is awful! It doesn't work either by using a spline border, or surface-only.
(http://www.dukecg.net/mutlistorey.jpg)
You must use multiple surfaces, one by each height level. Extracted from Forest 3.4 release notes:
- Overlapping of items at different heights is allowed in Generate mode (using multiple surfaces only).
In a distribution using XY coordinates, as Forest does, it's not possible to overlap items in a same surface. This is solved scattering by UV coordinates, one feature that will be added to the next Forest beta releases.
