Author Topic: How to avoid jagged Edge on Forest Objects?  (Read 3996 times)
suppenhuhn
« on: August 09, 2014, 10:55:09 am »
Hi!
I'm using ForestPack Pro with Max 2015 and MentalRay. I have always the following problem:
Very dense forest objects like gravel or grass using spline aereas always got jaggy edges - by the way this effect is very extrem using the lawn presets. If i switch the boundary checking from point to size the jagged edges are not gone - they only change "into" the spline area.
Which settings are required to avoid this effect? I want the forest object to fill exactly the area to the border but not beyond.
Thanks in advance.
Robert
« Last Edit: August 09, 2014, 11:37:39 am by suppenhuhn »
Re: How to avoid jagged Edge on Forest Objects?
« Reply #1 on: August 09, 2014, 11:49:21 am »
suppenhuhn
« Reply #2 on: August 09, 2014, 01:38:39 pm »
Thank you for the answer. Found that this tutorial : http://www.itoosoft.com/tutorials/tutorial_grass_edges.php is a good way to fix that problem - but it's "only" a little workaround than a nice solution ;)
Thank you!
mikegentile
« Reply #3 on: August 11, 2014, 07:32:40 pm »
try boundary checking to be the "size" of the object instead of the point(pivot)
BH1040
« Reply #4 on: August 15, 2014, 08:02:01 pm »
Is it a render problem possibly?
I had rough (noisy) renders with camera motion.
Raising the Mental Ray quality of aliasing to 16 and 16 cleaned up ALL the roughness and texture noise.
Hope that helps.
