Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
How to improve the transparency of my trees ?
« previous
next »
Print
Pages: [
1
Author
Topic: How to improve the transparency of my trees ? (Read 8757 times)
CK2516
Newbie
on:
June 29, 2012, 10:15:38 am »
Do you know how I can improve the transparency of my hedge?
I use 3ds Max 2012 and MR.
Regards
Logged
Administrator
Hero Member
Re: How to improve the transparency of my trees ?
Reply #1 on:
June 29, 2012, 11:23:14 am »
Are you using an HDRI map as background ? In that case, please try turning off Material->Forest Shader->Fast opacity in Forest.
Logged
CK2516
Newbie
Reply #2 on:
June 29, 2012, 01:59:55 pm »
I'm using only the mr Physical Sky. I'm doing the merge in Photoshop.
I've the same problem with or without the option of "Fast opacity in Forest.
For your information, I'm using the mr Photographic Exposure Control.
Logged
Administrator
Hero Member
Reply #3 on:
June 29, 2012, 02:24:04 pm »
The problem would be in the texture itself. Did you get it from the Forest library or is a custom texture ?
If that helps, here you can some tricks to remove the white halos using Photoshop:
http://www.sitepoint.com/get-rid-of-those-pesky-edge-halos-in-photoshop
Logged
CK2516
Newbie
Reply #4 on:
July 03, 2012, 08:30:21 am »
Yes, I use the texture from the forest library.
Thank for the link, I'll check it quickly.
Logged
Administrator
Hero Member
Reply #5 on:
July 03, 2012, 08:46:59 am »
If it is one or our textures, please tell me the exact model. We will check it and fix the map if necessary.
Logged
CK2516
Newbie
Reply #6 on:
July 03, 2012, 09:01:59 am »
I use Bush 5 and 8.
But, I've tried the tip of your link (contract selection) and it's correct.
If I'm alone with this problem, it' s not dramatic.
Frank
PS: sorry for my english
Logged
Administrator
Hero Member
Reply #7 on:
July 03, 2012, 11:55:50 am »
In any case, i just added to the to-do list a full revision of our textures. Some of them are from the earlier Forest versions, and need some revamp.
Don't worry by your english... it is not my native lenguage either.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
