Author Topic: How to improve the transparency of my trees ?  (Read 8760 times)
CK2516
« on: June 29, 2012, 10:15:38 am »
Do you know how I can improve the transparency of my hedge?
I use 3ds Max 2012 and MR.
Regards
Re: How to improve the transparency of my trees ?
« Reply #1 on: June 29, 2012, 11:23:14 am »
Are you using an HDRI map as background ? In that case, please try turning off Material->Forest Shader->Fast opacity in Forest.
CK2516
« Reply #2 on: June 29, 2012, 01:59:55 pm »
I'm using only the mr Physical Sky. I'm doing the merge in Photoshop.
I've the same problem with or without the option of "Fast opacity in Forest.
For your information, I'm using the mr Photographic Exposure Control.
« Reply #3 on: June 29, 2012, 02:24:04 pm »
The problem would be in the texture itself. Did you get it from the Forest library or is a custom texture ?
If that helps, here you can some tricks to remove the white halos using Photoshop:
http://www.sitepoint.com/get-rid-of-those-pesky-edge-halos-in-photoshop
CK2516
« Reply #4 on: July 03, 2012, 08:30:21 am »
Yes, I use the texture from the forest library.
Thank for the link, I'll check it quickly.
« Reply #5 on: July 03, 2012, 08:46:59 am »
If it is one or our textures, please tell me the exact model. We will check it and fix the map if necessary.
CK2516
« Reply #6 on: July 03, 2012, 09:01:59 am »
I use Bush 5 and 8.
But, I've tried the tip of your link (contract selection) and it's correct.
If I'm alone with this problem, it' s not dramatic.
Frank
PS: sorry for my english  :-\
« Reply #7 on: July 03, 2012, 11:55:50 am »
In any case, i just added to the to-do list a full revision of our textures. Some of them are from the earlier Forest versions, and need some revamp.
Don't worry by your english... it is not my native lenguage either. ;)
