Author Topic: How to get spacing along x evenly  (Read 957 times)
FP1509
« on: November 03, 2022, 09:48:39 AM »
Sorry if this is a very basic question
I tried looking up the forum but was unable to find something relevant
I want to create gaps in a object that I am scattering along x evenly
I tried adding null in Y Evenly but it does not give the result I desire.
Any work around or a relevant tutorial would be great
Thanks in advance...
Re: How to get spacing along x evenly
« Reply #1 on: November 03, 2022, 10:15:48 AM »
relevant tutorial:
https://www.itoosoft.com/tutorials/creating-panelling-and-wainscoting?back=page%3D7%26tag%3Drailclone
or try to set some size for Fixed Size Y on the Null segment.
« Last Edit: November 03, 2022, 10:17:49 AM by Dragan »
FP1509
« Reply #2 on: November 03, 2022, 10:26:06 AM »
Hi Dragan..
Thank you for the quick reply..  :)
The tutorial does not create horizontal nulls between a X evenly (See attached screenshot)
and I tried what you said about adding y fixed size on null segment.. doesnt work. (See attached screenshot)
Also I am look forward to assign Y size to the same Segment that I will be scattering on X evenly (Blue marking in 1st screenshot)
« Reply #3 on: November 03, 2022, 10:57:39 AM »
Can you share a scene and some more info about what you try to achieve?
This vertical division could come from your original Segment which is repeated on the Y-axis so Y evenly doesn`t affect at all if the distance is not right.
FP1509
« Reply #4 on: November 03, 2022, 11:13:31 AM »
Hi Dragan..
Thank you once again.. :D
It was in the size of the main object which I had set to be around 20'
That was the reason I could not achieve this.. (See Screenshot)
I reduced the base size of the object to about 2' and now it works.
Thanks a lot for the replies and interest to solve the problem
Best Regards.
« Reply #5 on: November 03, 2022, 11:16:44 AM »
Great!
Glad to help.  ;D
