Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Maximum Density ?
« previous
next »
Print
Pages: [
1
Author
Topic: Maximum Density ? (Read 4189 times)
DS4646
Newbie
Maximum Density ?
on:
January 12, 2015, 02:22:39 am »
I am curious as to what limits the maximum density ? the maximum objects, polys ?
Is it a RAM limitation or is it set in Forest pro ?
Surely its hardware and not a software limitation ?
cheers
Logged
Administrator
Hero Member
Re: Maximum Density ?
Reply #1 on:
January 12, 2015, 09:04:40 am »
Hi, you can see a detailed description of Maximum Density
here
We introduced these parameters to keep distributions within reasonable limits. If these values are exceeded, probably there are other ways to get it more efficiently.
Logged
DS4646
Newbie
Reply #2 on:
January 13, 2015, 01:11:58 am »
Still doesn't answer my question ? Is it hardware or is forrest pro limiting the amount of instances ?
I have some scenes that I can not cover enough ground with grass.
Regardless if I have it set to only show only in camera view.
Logged
Administrator
Hero Member
Reply #3 on:
January 13, 2015, 09:50:58 am »
Forest is limiting the number of instances. You can increase these limits if needed, with
Distribution->Max.Density
and
Display
parameters.
What extension do you need to cover ?
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Maximum Density ?
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
