Author Topic: Vray IPr showing different result to batch render  (Read 3151 times)
Keith678
« on: January 19, 2023, 03:06:38 pm »
I decided to follow this tutorial on iToo Grasscrete - https://www.itoosoft.com/tutorials/combining-concrete-paving-and-grass
I'm running the latest Versions of forest Pro and Vray and when I run render through MAX I get this result (Image_001) but when I run IPR I get the correct result seen here (image_002). This happened to me in other projects but I thought it was a project error rather than a forest pro error.
Any ideas why this is happening? It seems to happen when you add exclude objects.
Re: Vray IPr showing different result to batch render
« Reply #1 on: January 19, 2023, 03:19:37 pm »
Please, double-check if the RailClone object has the Use Instancing Engine option disabled - if not, disabling it, should help.
Keith678
« Reply #2 on: January 19, 2023, 03:59:41 pm »
Perfect solution. Thanks so much.
« Reply #3 on: January 20, 2023, 08:55:20 am »
You're welcome. I'm glad to hear, that it helped, and wish you the best results.
EU1144
« Reply #4 on: February 28, 2023, 01:05:54 pm »
Thanks, I almost went crazy
