Author Topic: Odd grayscale pieces using custom objects  (Read 2726 times)
TE4467
« on: April 07, 2015, 01:03:22 am »
Greetings
I have started to build my own custom library using different purchased or downloaded plants from evermotion and AutodeskSeek/Xfrog.  I have noticed on a couple pieces that I have either random greyscale buckets (using Vray3.0 and Max 2014) or just an altogether "off" transparency map if I leave the default .tiffs in for the opacity.
I have attached a few images to show you what I am experiencing.  Any advice would be much appreciated.
Thanks for your time!
-Greg
1st image: Straight Render after applying the optimize material through Forest Pack
2nd image: Diffuse taken out and colors added to help distinguish geometry
3rd image:  Diffuse put back in and a .png with alpha map put in the Refraction slot vs. .tif in the Opacity slot.  You will notice in this one it's better but there still seems to be a gray scale anomaly in the scene.  I have experienced this on more than one custom plant.
Re: Odd grayscale pieces using custom objects
« Reply #1 on: April 07, 2015, 10:58:32 am »
I would suggest you to check this "Problems adding 2D billboards to new library" related thread. You can find there a possible material set-up for a .TIF bitmap with Alpha layer included.
As for 3.0 V-Ray user, I highly suggest you to set the Opacity map Filtering to None and your Base Material for the Forest Material needs to be a VRayMtl (as explained here). Also please feel free to check our FAQ section's "Suggested settings for billboards" post.
If your issue persist, would you please send us your material / sample scene through WeTransfer to support@itoosoft.com to analyse it here. Thanks in advance.
Kind regards,
TE4467
« Reply #2 on: April 07, 2015, 07:43:19 pm »
Thank you, Michal.  I uploaded the scene to wetransfer as the suggestions did not change the affected maps.
Please let me know if I can provide further information.
-Greg
