Author Topic: in forest excluding railclone object  (Read 4495 times)
Alessandro Guida
« on: February 10, 2015, 12:46:24 am »
Which is the best way to exclude rail clone object in forest? converting in mesh before?
Re: in forest excluding railclone object
« Reply #1 on: February 10, 2015, 11:26:44 am »
There is no need to convert the RailClone object to a mesh. The calculation needed to obtain the correct "Exclude Area" will be performed automatically. For these purposes, the RailClone object should have the option Use Geometry Shader (or Use Instancing Engine in case, you are using the beta version) disabled.
In case of using the RailClone object as a Surface Area please check this post - "Can I use the Railclone Pro with point cloud display mode in Forest Pro Pack?"
Kind regards,
Alessandro Guida
« Reply #2 on: February 10, 2015, 05:31:19 pm »
done is still no perfect
working on this parameter over railclone object in forest is helping...
« Last Edit: February 10, 2015, 05:38:41 pm by Alessandro Guida »
