Author Topic: problem distributed rendering and animation  (Read 3106 times)
Tarpan
« on: May 12, 2015, 09:43:44 am »
problem rendering animation and distributed rendering function while the falloff. The first frame of the rest is not true test, as well as for distributed rendering. the attached image
« Last Edit: May 12, 2015, 01:56:55 pm by Tarpan »
Re: problem distributed rendering and animation
« Reply #1 on: May 12, 2015, 05:53:10 pm »
We've been doing some additional testing here (under several conditions), but we are unable to reproduce your troubles and most probably it's related to use of different release(s) on some of your render nodes. Please follow this Distributed Rendering issues post to double check, it's not related to an installation error.
If the problem persist, would you please specify used Forest Pack / 3ds Max / V-Ray versions? Thanks in advance.
Kind regards,
